Dear all,
How can i mesh the engine mounts and other huge automotive components by hexa meshing.
Dear all' date=' How can i mesh the engine mounts and other huge automotive components by hexa meshing. [/quote']you should create mappable regions or if accuracy is not so important you could use shrink wrap option.another way is trying the solid layer/shell layer options. you should check the solid meshing sub menu and also the tutorials.
Thank u very much for the reply........very kind of u:)
not at all /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
