Hi there,
I have tow questions concerning the display of results with composites.
1) I would like to use the Systems Review Dialog to check the orientations of single plies in my composite model (modelled ply based for Optistruct with PCOMPP property). As you can see in the attached picture the single plies are not available for selection in the Systems Review Dialog even though they are available as layers in the contour plot menu.
In the documantation for HyperView it is stated: 'For reviewing 1D Elemental, Ply, and Material systems, the Advanced Result Math template must be selected in the Load Model panel when initially loading the model and result file. In addition, a solver input deck is also required as the model file.'
I Use the advanced math template and in the Load Model panel I only can select two files (load model (*.hm), load results(*.h3d)). How can I add the solver input deck (.*fem)?
Or do I need to change other settings?
2) In an Altair webinar video (see min 19:56 in https://altair-2.wistia.com/medias/zqn515pj8i ) I have seen that composite stresses can be displayed as tensor. With my seetings they are only available as scalar values. How can I display them as a tensor according to the video?
