Hi there,
I have met a problem with Inspire concerning polyNURBS modelling and transfer the model to stp and stl file. After using the optimization function I use the polyNURBS function in Inspire to build up the model. Then I tried to transfer the model to stl file for 3D printing, but the model was damaged when I open it in 3D printing software. I also try to transfer it to stp file to try to open it in solidworks, but I found the polyNURBS solid change to surface from solid part during the file transfer from stmod format to stp format, and damages can be found on the polyNURBS surface after the transfer. I have try many times but always get the same problem. I wonder what was the reason of this and how to fix it. I have attached the relative files.
Thank you
