Hello, I was trying to make an analysis with the 2 d road from analysis wizard, but it didn't work, no road was created and the car only fell during the task, could someone please help me?
Please let us know whether you notice any error or warning message when you add analysis from Analysis wizard.
When creating from assembly wizard, have you selected any driveline configuration for the full vehicle?
No i didn't, there's no error message, but the car only fall during the analisys.
Hi Tiagoara,
Try this:
When creating the car assembly using Assembly wizard, choose a driveline configuration (like front wheel drive) and select the analysis type like single lane change analysis and check whether road is created or not.
Yeas, the road is created.
I hope you are able to see the car running on the 2D road...
