Non-mappable solid problem
I have split my geometry using the trim panel. I did this with a surface. Can anyone tell me why the section that has not been given a mesh in my .fem not mappable? I get the message 'non-mappable(2) along-faces form 0 loops need 1.' I'm guessing I have to split the geometry further but I'd like to know why this has happened.
Thanks,
Laurence /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
You're speaking about 'geometry' but your .FEM has not.
Share your HM.
0 -
Do more splitting!
0 -
Wow, thank you so much!
0 -
Hi HTH,
I am attempting to trim again with similar geometry, I have got as far as my knowledge will take me, but am struggling to repeat the same result you came to. I can't create the angled trim that you produced.
Kind Regards,
Laurence Maskell
0 -
Hi HTH,
Apologies for the spam of messages, I figured it out. Not to worry.
Kind Regards,
Laurence Maskell
0 -
I am also facing a problem with 3d meshing. The solids are non-mappables. I have tried to trim using planes, surfaces, lines and even after multiple trimming, the solid is unmappable.
Can somebody please help me?
Kind Regards,
Kaustubh
0 -
You have to do a lot of splitting to get mappable. Have a look at my mesh.
0 -
Can someone please help with the mapping of the circular solid. I have tried trimming in various planes, yet there seems to be some non-mappable surfaces.
Kind Regards,
Kaustubh
