I have a question on spotweld connectors. I have the following two components with shell mesh. I have a hard time choosing which option to use in spotweld. Pls help me. Please explain which one we should use and when?
1) Mesh Dependent - adjust realization- find nearest nodes
2) Mesh Dependent - adjust realization- project and find nodes
3) Mesh Dependent - adjust realization- ensure projection
4) Mesh Dependent - adjust mesh- remesh
5) Mesh Dependent - adjust mesh- smooth
6) Mesh Dependent - quad transition- imprint
7) Mesh Dependent - quad transition- skip imprint
Which method is good and if I use different methods will I get different results?
I have used (Mesh Dependent - adjust mesh- remesh) but then I feel that when I do this because of remesh my elements become smaller and fail in quality.
Thanks,
Datta
