Hi everyone,
I'm trying to get results from Hiperview and I only know basic functionalities.
I need to calculate a factor of safety for laminated composite, but for TsaiWu or Hoffman, the factor of safety is not straight forward and need to be computed with the stress values.
I dig a little bit and found the TsaiWu reserve factor on the derived result in the composite library as TsaiWuRF.
I need to apply this and would like to do the same with the Hoffman criteria.
Can anybody explain me how to get the stress table, set table, ply table and whatever is necessary to use this function? Or give me a tutorial which would explain me this.
Thank you very much,
Best regards,
Gonçalo
