Error 1000, Field #4
Altair Forum User
Hi All,
I am simulating two components connected with a bolt. I have modelled the bolt with a PBEAM.
I have got the following error message, what is field #4?
'PBEAM 2 10.0 0.0 0.0 0.0 0.0'
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 4.
Thank you!
Field#4 is area of cross section, in your case , it is 0.0
field#5, #6 ,.. of your data is 0.0 also.
You need to create a beam section and assign it to PBEAM, or input correct value to the fields
