I need to access the distance between two nodes using a tcl file.
How can I do it ?
Thanks
Hi Benoit,
you can use the command hm_getdistance to do that
Hello Toan,
Thanks for your help.
Hi
It is hm command
Replace ( and ) and , by space to get tcl commands
If you are searching for closest node on surf, use hm_measureshortestdistance, do not use loops which will slow down program
Hi Benoit, you can use the command hm_getdistance to do that
Hello
When I use the command hm_getdistance HyperMesh returns 4 values and I need to put the fist one in a variable distance.
(Documents) 4 % hm_getdistance nodes 3723 5317 0 0 68.91864249631689 41.6426000000006 54.90046920132 -1.2694999999999936
How can I isolate the first value in a variable?
thanks
For what you want, you need to use TCL command: lindex.
this command is used to return the element from a list.
Try the following code.
Cheers
set distance_list [hm_getdistance nodes 3723 5317 0]. set distance [lindex $distance_list 0]
