meshing with hex8, tube with bore and node compatible areas
Altair Forum User
Altair Forum User
I've got problems meshing a part of a tube. Like you can see in the picture it's the middle part and I have to connect the mesh to the other meshs.
I'm quite new to HM so meshing with node compatible meshs with hex8 seems to be quite difficult. The tube hast rings on it assembled with a shrink fit, therefore I need it to be node compatible.
Thanks for your help !
<?xml version="1.0" encoding="UTF-8"?>post-31592-0-65035800-1398848615_thumb.j
  • Altair Forum User
    Altair Forum User
    edited May 2014
    Send me your model. I'll show you how to do that. It's so simple.
  • Altair Forum User
    Altair Forum User
    edited May 2014
    Hello Halscheb,
    Mesh the outer and inner surfaces with same no of elements and also try to match the no of elements with the existing mesh.
    And then
    go to > 3D > Solid Map > general give all the parameters like source, destination geometries etc., Give the holes lines as 'along geometry',
    Hex mesh is a bit difficult compared to other mesh types. Try doing it with more number of iterations.
    Regards
    Raviteja
  • Altair Forum User
    Altair Forum User
    edited May 2014
    Hello Halscheb,
    And then
    Regards
    Raviteja
    May be this option works but its leads to element quality issues. try it.
