A problem in an interface Type21
Altair Forum User
Altair Forum User
When I run the hf file of my model created just as per the tutorial 'Simple draw forming', at the begining of the process the solver didn't prompt fo any error. But at the end of 7th animation file, the process terminated saying 'The run encountered a problem in an interface Type21: You may need to check if there is enough clearance between the tools'.
Please help me to solve the problem.
Welcome!
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Hi Soumitra,
    I am having the same error. Did you find any solution for this type of error?
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Hi Shripal,
    Can you please share the files so that we can check and suggest the possible workaround.
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Hi Shripal,
    Hi George,
    I sent you .hf file on dropbox. Please check it. I am looking forward to hear from you soon.
  • Altair Forum User
    Altair Forum User
    edited November 2020
    Hi Shripal,
    Please find the attached *.RAD file with the result file.
    Also, i have switched off the adaptivity and setup the model. Do look at the results and revert back.
    santhu
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Hi Shripal,
    santhu
    Hi Santhosh,
    Thank you for sharing this file. But i want to run the simulation using connecting material (resin) between the layers. In this shared file you deleted the resin components. Can you guide me how can i setup the simulation with resin betweeen the layers?
    Shripal
Welcome!
Welcome!
