Hi ,
I did my optimization in optistruct. I want to edit my optimized results to make it more presentable . Is there a way to import results form hyperview/hyperworks in INSPIRE and do such thing ?
Thanks in advance !
You can use OSSmooth to export the optimized design to any geometry format and import the same in sT Inspire.
In HyperView, export your results doing : Tools > Export > Iso Surface, use the .stl in inspire
