For incremental Radioss forming operation, I have used b-meshing for blank and verified that there is no single tria element and the other(die) parts are meshed with R-meshing.
I setup the tool by die and automatically created the punch, binder and die cavity.
Then I performed the Auto Process in which I applied Autoposition parameters and ran the file.
But I'm unable to obtain the results as the process stumbles around the error saying 'Unknown command line argument: DIE_0000.rad'.
Also it does not produce _0000.out file.
