I want to evaluate the near and far field of a qi Transmitter coil. The geometry was built in EAGLE and importetd using GERBER. When placing the microstrip ports at the beginning and the end of the coil, the vaidation runs with no errors, but the solver says the following Error message
    ERROR 0 output requested in line 35 of the file Qi_A32_Coil_FR4.pre: The mesh instance of port 'Port2' is completely inside a metal entity
    ERROR 0 output requested in line 36 of the file Qi_A32_Coil_FR4.pre: The mesh elements were removed and the port is therefore invalid
    ERROR 30299 in line 37 of the file Qi_A32_Coil_FR4.pre: Termination due to user request (EXIT statement)
    I reduced the mesh size at the ports to a minimum. The attached File is the Coil with a FR4 Substrate below.
