Is it possible to find all the mesh nodes that lie on a plane (defined by 3 points - A,B,C) through the use of .tcl or command script?
Many thanks,
Wensong
yes, it is
first you read help about command *createmark with option 'on plane'
then thinking how to construct such plane from 3 points
yes, it is first you read help about command *createmark with option 'on plane' then thinking how to construct such plane from 3 points
Thanks Tinh,
Your help is so much appreciated.
Cheers,
