Hi, what are the steps to make a solid mesh inside the doughnut shape solid mesh so that all nodes are matching those of the doughnut please.
Thank you
Use linear solid option by extracting faces of solid elements.See attached video for steps.
Hello.
Thanks but I did not write my question well.
I meant how do you mesh the hole inside
Use spline command to mesh circular region with mesh delete surface ,try to have same mesh on opposite side & use Solid map option to generate hex mesh.
I don't think you can do that with some ... clicks /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
That's doable, but you need some manual works.
I have tried manual but after equivalencing it's still not working
Hi I''ve tried creating one surface mesh on one side and then create a solid map with node path but it's still not working. Any ideas please?
I can't even create two surface mesh and map in between.
Create surface mesh on one side. Make node equivalent.
Project (by copying) surface mesh to another side. Make manual correction to equivalent nodes.
Once you get two surface meshes, you can do 'linear solid'.
Finally, do equivalent again.
Hi Dilen,
You can ruled one side of the hole and position it to other side by using position tool and equivalence it (Manually). And create solid mesh using Linear solid mesh with node path method. I have created and it is working properly. hile equivalencing, make sure that no. of nodes should be equal in both faces where solid elements need in between.
Hi Dilen, You can ruled one side of the hole and position it to other side by using position tool and equivalence it (Manually). And create solid mesh using Linear solid mesh with node path method. I have created and it is working properly. hile equivalencing, make sure that no. of nodes should be equal in both faces where solid elements need in between.
Not only 'nodes should be equal in both faces' but also 'element topology should be compatible on both faces.
In other words, even with the same node number, you can not do linear mesh from Quad elements (on 1st face) to Tria elements (on 2nd face)
Hi Any chance I can get a video of the steps please. I tried and still can't get it.
Here's my video:
Thanks very much. One thing is that when I create the mesh on one side the surafce mesh nodes are not near the nodes on the solid mesh. I adjusted the number of nodes but it still does not equivalence in the right way.
