Pressure import from VWT to HyperMesh
User: "Altair Forum User"
Updated by Altair Forum User
I want to apply the loads extracted from the VWT analysis to the model in HyperMesh.
As per the below procedure suggested by Altair colleague , I was able to import loads but the value of pressure was zero and in contour loads option - I get 'no results available for contour'.
I was told to do the following:
1. open vwtanalysis.acs file in AcuSolve.
2. Use AcuOut and variable 'pressure' was exported in 'table' format and 'nodal Output' type .
3. Then , using Linear interpolation option - pressure was created.
Although pressure is generated , in the HyperMesh, there is no value assigned to the pressure applied to the surface elements on the nodes on the face. (Snapshot attached)
How can I solve this issue? It would be nice , if somebody can help in sorting this problem.
Looking forward to a timely response.
Thank you.
Garima
<?xml version="1.0" encoding="UTF-8"?>post-37680-0-09227900-1436794322_thumb.p
1 - 2 of 21
    User: "ydigit"
    Updated by ydigit
    Are you getting non-zero pressure values in the .OUT file generated by AcuOut?
    If yes, then probably the HyperMesh forum might be more appropriate to address this issue. You will get more response image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    OP
    Thank you for the reply.
    Yes, I am getting non-zero pressure values in the .OUT file.
    Ok, I will post in HyperMesh forum.
