how to merge faces in hypermesh
Is there a way to merge the faces shown in the attached picture to form one face, please?
Thanks /emoticons/default_smile.png' alt=':)' srcset='<fileStore.core_Emoticons>/emoticons/smile@2x.png 2x' width='20' height='20'>
Thanks. I have tried that. Howvere, I need to partition the part into mappable regions. Even if I toogle the edges off, sometimes point and edges are created when 'off edsges' intersect the partitioning lines. Is there any way to get rid of these please?
Thanks
If you want to make 'full hexa' meshing, it's not possible. Here is my test :
https://dl.dropboxusercontent.com/u/7959896/HW/mtcart.hm
There is small solid for which you have to fill with TET/PENTA.
Thanks. I saw that your technique of partitioning is way diffferent to mine. By any chance do you have any tutorials on partitioing, please?
No tutorial, just 'feeling' and 15 years of experiences /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
Try: Geom => edge edit => toggle => turn off edges
