how to extract time step and corresponding contour value by using TCL/tk
1.) I want to extract data for only specific set of elements but I am getting contour value all element. I don't know what is mistake
proc QueryAndExportELEM {FileName} {
mh GetSelectionSetHandle ssh [mh AddSelectionSet element]
ssh Clear
ssh Add 'dimension 2'
ssh Add 'dimension 3'
foreach elem {11 22} {
ssh Add 'id $elem'
mh GetQueryCtrlHandle qc
qc SetSelectionSet [ssh GetID]
qc SetQuery 'element.id contour.value'
qc GetIteratorHandle qciter
puts 'Element ID: $elem'
set fp [open $FileName w]
for {qciter First} {[qciter Valid]} {qciter Next} {
puts $fp [regsub -all \{ [regsub -all \} [qciter GetDataList] ''] ''] }
close $fp
mh RemoveSelectionSet [ssh GetID']
qc ReleaseHandle
qciter ReleaseHandle
ssh ReleaseHandle
2.) How I can extract time step and corresponding contour value to .csv file by using TCL/tk. ??
Hi Vikas,
You can add /ANIM/NODA/DT in the engine file to get animation Files containing nodal scalar data.
Can you try with this?.
Hey george
How to add /ANIM/NODA/DT in the engine file.My code is same as above code .
can you help me.
Thanks
Hi Vikas,
Which solver are you using?. The above mentioned keyword is for RADIOSS solver.
and i want to find max stress by using TCL/TK script but contour.value in set query giving N/A
please answer as soon as possible.
Thanks in advance
I also have same issue at the place of contour value am getting N/A
