Hi, how can i fix this
Dear Otavio,
It looks like there is a problem with the inlet.
Could you please check the ingate has been well defined (check if it is inside the geometry and in the same plane)
Please check too the element size, 1mm seems too small for this part.
Best regards
Hello all, I have the same problem, I´m following C2C tutorial instructions introducing recommended parameters and using STL file provided by SolidThinking and the same message error appears. Please your help to solve this, actually this error appears with any STL file I´m trying to mesh.
Hello Mario,
Is this happening every time? Could you please try with a different model just to be sure that it isn't a problem of permissions?
You can contact me to check this in a webmeeting.
ptorne@altair.com
