Combining Hex Mesh
Updated by Altair Forum User
Sir,
Is it possible to combine hex mesh, like we do for 2D elements?
In my case, I have a layer of hex mesh, the elements of which have been split (every single element is split across all of its side using 3D>Split>Solid elements (split into hexa)pannel).
Now I want to combine pairs of two elements within each layer separately.
How is it possible.
1 - 2 of
21
Altair Community Member
Updated by alpha_21885
I also faced this issue few years ago but now I can do this in few clicks with Simlab (Hexa Layer modify function). If you do this a lot, I recommend you use Simlab (import to Simlab >> Edit >> Export to HM).
There are few scripts available on Altair HyperWorks Script Exchange site.
Please check if those scripts.
