Hi all,
I have to insert a new material in the HX library to use it with Polymer_processing. I have the Shear-Viscosity curve, and so i want to use the Fit Material command, but it doesn't work. After loading the file the procedure doesn't create any material.
I also tried to create a new environment variable like written in the Help, but the results are the same.
can anyone halp me?
thanks,
best regards
Stefano
