Problem with output file
Updated by Altair Forum User
Hi everybody
I am new with HyperMesh and I've a little problem (maybe very simple)
In my first tutorial I imported a geometry but when I launch the simulation it doesn't work
and appares a message in the bottom: 'Output file not found' (in italian: 'File di output non trovato')
Can someone help me? Thanks
1 - 6 of
61
Thank you
I'm using BasicFEA at the moment
I import this example form the directory 'tutorials': Full_Motion_TV_Mount_Partly_Open
I run the simulation but I've no result, just that message
New Altair Community Member
Updated by Rahul Rajan_21763
Could you share us .fem file?If yes please share using below ftp link.
Regards
Rahul R
I've solved! It was a problem with solver installation! Thank you for the support!
What solver you are using.If your input deck is complete then it should write out file.Provide some more info about your problem.
Regards
Rahul R
