hi
why i dont get hypergraph 2D and 3D in my pannel
i have this picture http://cjoint.com/?EBwuaSJ7d6m
thanks
Hi jeunehomme
You can open HyperGraph 2d and 3D from installed program folders or from client selector.
on Windows machine>> All Programs>> HyperWorks 12.0>> select HyperGraph to open HyperGraph.
or
You can open through client selector (refer to the image):
To see Client Selector toolbar, Goto View>> ToolBars>> HyperWorks>> Client Selector
Please do the above and note you can only activate the HyperGraph 2d and 3d toolbars once you are in the respective application chosen as above,
HI
thank you to both of you
which file to choose to see graph of displacement , stress ....
thank tou
Depending on the solver, usually H3D
i use optistruct
i select H3D file but i get this case : http://cjoint.com/?EBxm6ZSjP28
Can you check if you have the latest Graphic drivers installed? I have seen this issue on HG clients only and updating graphics driver resolved it.
Note - The 'update driver' via Windows' updater is not always the latest driver for that device, it is just the latest WHQL driver given to Windows.
Going to the manufacturer of the graphics card , e.g. Intel, Nvidia or AMD , will ensure the latest driver for that device.
FYI, Make sure you “Perform a Clean Install” while updating the drivers.
Please try setting these variables one by one and then together also,
HW_DISABLE_MULTISAMPLE=1 or the HW_DISABLE_FBO=1,
i try to do what you conseil me , but when i instal update driver for my graphic card i get this probleme when i lunch hypermesh :
http://cjoint.com/?EByo6oguVtu when i clic ok i get this message http://cjoint.com/?EByo7e9GsdC
You might have to reinstall the tool,
Revert to the older driver and try with the environment variables instead.
how Revert to the older driver and try with the environment variables instead.
