🎉Community Raffle - Win $25
Join and Win
How to limit the rotation of a revolute joint?
User: "Faleh Al Mahmoud"
Altair Community Member
Updated by Faleh Al Mahmoud
Hello All,
Is there a way to limit the rotation of a revolute joint in the Hypermesh LSDYNA environment? More specifically, I would like the revolute joint to only allow rotation between 0 and 15 degrees CW (Crudely illustrated below).
Thank you for your help!
1 - 2 of 21
    User: "Rogerio Nakano_21179"
    New Altair Community Member
    Updated by Rogerio Nakano_21179
    Hi
    I suggest you to look into the solver manual , so you can verify the keyword parameters you need to set.
    In case you may use Altair Radioss, you can define joint with /PROP/TYPE45(Kjoint2) and Type=2 is the revolute joint type. In this you can define rotation limits.
    I hope this is helpful
    Regards
    OP
    Hi
    Regards
    Thank you Rogerio! I will check to see if there is an equivalent rotation limiting parameter in the LSDYNA solver.
