I'm working with linear dynamics (modal, harmonic and transient) analysis in OptiStruct and I wonder if I can extract the results of displacement, velocity and acceleration in list format or export to excel?
Solver writes default output in H3d format which you can load in Hyperview and check results.(.out file ) You can open in Text pad and check output.
What is the end objective of csv file?
I don't know if I understand your question correctly, but I intend to to join the data extracted into arrays for subsequent matrix calculations.
In Hypergraph you can plot output of Harmonic analysis & same can be exported in csv format. See attached screenshot.
Thank you!
