   	I am trying to run parameter sweep in FEKO. I used the plugin as I am using version 7.0.  My license allows parallel computing and it's enabled in the CADFEKO application window. However, I am getting a note when I am running the batch file stating that I am using sequential version rather than parallel. Does anyone know how to rectify this?
   	Thank you
