Warnings while importing the files
User: "Altair Forum User"
Updated by Altair Forum User
Hello
When importing a nastran file into HyperMesh I find warnings as shown in the image Can you explain to me where these warnings come from? and how to correct these errors?
Thank you
1 - 6 of 61
    OP
    The reason for the warning message is, those case control cards are not supported in HyperMesh-nastran template and will be written under the UNSUPPORTED  CONTROL CARD found in Analysis> control card panel. You can edit this control card and when you export the file, those changes will be considered.
    You can also try updating to the latest HyperWorks version, HyperWorks 2017,  where these may be supported.
    OP
    Hello @George P Johnson,
    thank you for your reply, if you allow me to know how i can modify these unread cards for corrected errors.
    thank you in advance.
    OP
    These are  optimization cards which are not supported in HyperMesh>> Nastran profile and you cannot run the same.
    I recommend you to try with OptiStruct for optimization. Many tutorials and webinars are available for the same.
    OP
    @George P Johnson
    Hello
    if i want to use functions of hypermesh in a script made by myself (example: apply the function: import solver deck) which allows me to display the window to choose the command file then import it.
    if anyone can help me I would be very grateful.
    OP
    I think you are asking for basic scripting tutorials.
    We have some online Help tutorials which shows customizing in HyperMesh. Please go through the same.
    OP
    HI
    @George P Johnson
    you can skip the link please:)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
