i have download the supra files from altair website. And in that report templates,the graphs are with respect to time(in x co ordinate) and how to change the wheel displacement as a x co ordinate instead of time.
Hi muthukaruppan
It will be easy if you open the .abf or any plot file from the working directory and plot the graph as per your requirement.
You can change the X Co-ordinate by using the Defined Curves panel after the template loads. This is the third button in the tool bar and is a curve with an green x on top of it (13.0).
Once in the panel you can choose your curve and change the x axis of it.
