Occasionally after I run a simulation, it was all run fine without any errors, but when i got to open it in HyperView i get the following:
2017-07-21 15:36:15 HyperWorks Information: H3D File Opened: C:\Users\Brandon\Documents\HyperWorks\Training\Misc. Files\Contact Test\Radioss\Cube on Cube\v2.h3d
2017-07-21 15:36:15 HyperWorks Error: H3D file Table of Contents failed to read.
2017-07-21 15:36:15 HyperWorks Error: Error: failed to read model from 'model' resource.
2017-07-21 15:36:15 Application(General) Information: Error creating result math analysis
I have noticed that it will only really occur when I change the Engine File. For example If I set the Engine File to this:
It will all work perfectly, and the animation will show correctly. But if i want a smoother animation with more frames, I want to increase the animation output, so if i change the .1 to something like 0.01 or 0.02, I get the error shown above. So just to be clear here's what the Engine File shows when I get the error.
I am new to using Radioss so not sure if I am just misunderstanding something, but not sure what is going wrong. I am also not sure if this would be a Radioss issue or a HyperView issue, but it renders fine from Radioss and creates the H3D file so I assumed it is a HyperView thing.
