I am using the function sewing tools function from Aerospace module. I have a doubt. How can I verify whether all the GFEM are attached to DFEM? via RBE3.
Thanks.
Are you getting any error while solving?
Basic objective of sewing tool is to connect GFEM to DFEM using RBE3.So its all about setting of height & node snap parameter.
If it is creating RBE3 in unnecessary location then you can recreate by not selecting elements of those region.
To verify this i dont see any option.
Regards
Rahul R
Hi, Are you getting any error while solving? Basic objective of sewing tool is to connect GFEM to DFEM using RBE3.So its all about setting of height & node snap parameter. If it is creating RBE3 in unnecessary location then you can recreate by not selecting elements of those region. To verify this i dont see any option. Regards Rahul R
No error while solving.
The rbe3 elements look fine visually. But, post processing, I get huge displacements and stress. I am curious to find out whether the connection between GFEM and DFEM didn't happen correctly.
Thanks Rahul.
Hi Giri,
You can use Edges panel to check if there is any nodal disconnection among the elements.
Go to Tools page>> Edges>> Select all elements/components>> Preview equiv (to see the disconnected nodes)>> Equivalence connect the disconnected to the nearest node.
Hi Giri, You can use Edges panel to check if there is any nodal disconnection among the elements. Go to Tools page>> Edges>> Select all elements/components>> Preview equiv (to see the disconnected nodes)>> Equivalence connect the disconnected to the nearest node.
Good idea. Never thought about that. Will give it a try.
Thanks Prakash.
How do you choose the best choose the best product among the ones listed here?
https://fitsewing.com/best-sewing-machine/
I am using this tool and I am checking it manually to know if all required nodes connected with RBEs, as I have not much in my Model. Sometime I use matrix browser and excel to map the RBEs connected nodes vs list I make from GFEM to DFEM.
but it will be really helpful if we have any check option available to make sure of all connections within HM itself.
Thank you
