🎉Community Raffle - Win $25
Join and Win
Fine mesh transition
User: "Altair Forum User"
Updated by Altair Forum User
Hai,
This is guna from Renault Nissan. I want to know the command to get 'Good transition from 10mm mesh to 2 mm mesh'.
Image x --> How I need the mesh transition to be
Image y --> How I get mesh transition in HM (by Automesh command)
Note : I am using HM v14.
1 - 6 of 61
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Could you please explore refine by pattern command.Refer attached doc & screenshot.
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    When you have big diffence in element size, it's better to make several transition zones (geometru splitting). By this method, in stead of do 10mm=>2mm, you can do 10mm=>8mm=>5mm=>2mm.
    User: "GAJENDRA KUMAR NHAICHANIYA"
    Updated by GAJENDRA KUMAR NHAICHANIYA
    These videos will help to learn 2D and 3D mesh transition technique.
    User: "Adriano_Koga"
    Updated by Adriano_Koga
    hi Guna,
    you're looking for the 'redo connectivity' option in automesh panel.
    I'm sorry, i've sent the message before the end.
    Here, setting 'redo connectivity', when you select elems and remesh, you can choose number of adjacent layers to be in the transition zone and if it will change the inside elements or outsiders.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.e7bea66a296565ef4519f99110f46529.png
    a couple more images from the result. I've started from a 10mm regular mesh, and i've selected the elements to be refined.
    I've remeshed to 5mm target, and kept 2 layers for transition and 'inside' disabled, so that the selected region was remeshed to 5mm and the transition was kept outside. taking 2 adjacent layers.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.64b58233cce0b00fbd69985ab96c944b.png
