Background: A .igs file of a bone model is imported into Hypermesh. Different regions are 'cut with plane' and meshed individually. Tetramesh option is used to create a meshed volume by rejoining different regions.
Problem:Due to a small region of uneven cut, tetramesh option does not work. The even edge is shown in figure, affecting 3 different surfaces. Suggest a method to avoid surface edge problems.
If you are working with surfaces, you will need to clean up that sliver area with our geometry cleanup tools.
https://help.altair.com/hwdesktop/hwx/topics/tutorials/hwx/geometry_cleanup_t.htm?zoom_highlight=geometry+cleanup
https://www.youtube.com/@AltairHowTo/search?query=geometry cleanup
If you are using the surface mesh, you will need to remove those small elements and equivalence the unattached edges.
