During analysis, I cant able to find Bulkdata option in Radioss.
If I choose option other than Bulkdata, In 'analysis' menu panel, Loads and Constraints option hides.
Thank you in Advance
Just use profile Optistruct to setup your analysis and run by Optistruct.
Thanks for the reply tinh,
I analysed simple beam element results in failure while opening HyperView.
Only the element alone displayed, no results.
Im sure that Boundary conditions are correct.
Thank you.
Did you enter iso panel and show result?
If possible please share your model *.fem file
