Hypermesh batchmesher minimum 'target element size' limit
User: "Altair Forum User"
Updated by Altair Forum User
I am using batchmesher for meshing a hm file with target element size of 2. In Criteria dialogue box it showing some error in 'based on time step' row under Good/worn/fail/worst columns. I have tried to change Younge's modulus and density but after changing these parameter it is taking default value when i am loading the criteia file again.
Is there any minimum limit of target element size for batchmesher? if not then how can i select lesser element size (2 or <2) with no error in other parameters?
Thanks in advanced
<?xml version="1.0" encoding="UTF-8"?>post-39054-0-76152800-1439443267_thumb.j
1 - 4 of 41
