Hi all, im doing the CFD-1300: Plane 2D Meshing with BL tutorial. But even following the tutorial this error appears (attached image) How can i solve that? Thanks
This look to be a issue.For now can you use 2d Smooth BL.
me too.
I also have this problem like this.
when I do 2D Native BL(planar), I always get a error notice' error parsing line***, read -1 entries'.
what is the reason? How can i solve this?
who can help me?
I confirm this bug with Hyperworks 2017.1.
Hello, I have exactly the same problem with my academic licence while doing tutorial CFD-1300: Plane 2D Meshing with Boundary Layers.
Has a solution been found since 2017 ?
Thank you very much.
Why not try newer release? 2019?
Thank you for the rapid answer. I have this problem while trying this tutorial on 2019 educational licence. Apart from the tutorial, I tried with a simple model of my own and I also get an 'Error parsing line 713, read -1'.
Then I tried to change a few things to fix my model and now I get 'Error parsing line 902, read -1'...
