Ask: How to set the shortcuts by command
User: "Altair Forum User"
Updated by Altair Forum User
I'd like to customize a shortcuts to let me get the function quickly to pick up the nodes attached with line.
I just know set the hm_pushpanel {rigids} to the subpanel (1D--> rigids), but what is the related command to let me also include below action?
1) select 'multiple nodes'
2) select 'calculate node'
3) select 'by geoms'
4) select 'lines'
I try to key hm_pushpanel {rigid} {multiple nodes} {calculate node} {by geoms} {lines}, but it is not workable.
Could anyone teach me how to set it??
BTW, does anyone know where I can find the command list in the help document??
Thank you in advance.
1 - 2 of 21
    User: "tinh"
    Altair Community Member
    Updated by tinh
    customizing panels are not usual documented fully. you can learn via sample script
    example:
     set ItemNumber [hm_getitemnumber rigids 'calculate node'] set ItemOwner [hm_getitemowner rigids $ItemNumber] hm_setpopup rigids $ItemOwner $ItemNumber
    with select nodes 'by line'. I didn't find direct command yet (using mouse hooking by twapi can do it, but it's a bit complicated).
    if you want, try invoking sub proc like this
     proc appendnodesbyline {{nodemark 1}} {      *createmarkpanel lines 1 'Select lines:'      if {[hm_marklength lines 1]} {            eval *appendmark nodes $nodemark {'by lines'} [hm_getmark lines 1]            hm_highlightmark nodes 1 h            *clearmark lines 1      } }
    OP
    I appreciate your reply. I think it's hypermesh's limitation and can't support to write the code into the shortcuts setting directly.
    Anyway, I'll try your suggestion.
    Thanks again!
