Does anyone have experience of simulating lumped element within geometry in FEKO?
User: "Altair Forum User"
Updated by Altair Forum User
I want to add a lumped capacitor between two metallic strip in FEKO (in construction that capacitor will be etched to metallic plate), if I want to use non-radiating network as lumped capacitor, which kind of port, should I use so that it can be connected to that network? I use edge port but it has no effect because lump element sees infinite impedance from that port.
another port doesn't appear in schematic view and others couldn't be used.
thanks.
1 - 1 of 11
    User: "MartinV_20771"
    New Altair Community Member
    Updated by MartinV_20771
    It should work with an edge port to which you assign a load. The edge has to be a shared edge between two metal faces in the same union. In the load you can specify the capacitor value or the complex impedance.
