Dear All,
i hope to find a solution for my problem.
To avoid self-intersection i check my component for intersections and fix problems when intersection-problems occur.
I would like to use TCL to make this possible. I use following code:
*createmark components 1 'compname'
*checkpenetration components 1 0 0 1 0 0 0 0
Using these commands Hypermesh will find intersections which exist on the component. As from now, I need a command to fix all found intersections. I have to do that manually by clicking on the 'Automatic Intersection/Penetration Fix' Tool so far. Is there a way to do that automatically?
Thank you very much
/emoticons/default_smile.png' alt=':)' srcset='<fileStore.core_Emoticons>/emoticons/smile@2x.png 2x' width='20' height='20'>.
