Whenever I use the R-Mesh option for Geometry meshing, the mesh quality I get is seems very unacceptable (as I perform quality check). But the solver (Radious_One Step) provide results without any flaw in its computations.
However, when I perform Automesh, followed by quality check (warpage, Aspect Ratio, Skew, jacobian, Mini. length, angles, etc; without any change in other steps (tonnage, material,etc), the solver fails to produce results as it stumbles with an error (Radioss/Optistruct Error 20205) in the process.
Does this meshing (with probable unacceptable meshing quality) through R-mesh panel (without any quality refining) affect the accuracy of the results?
