how can I get from a Modal Analysis the Modes of my geometry in Hz? Till know i succeed to do the analysis, but i just get out the deformation in meters.
Thanks guys! Daniel
Each mode F should be in cycles / second i.e. hertz in my opinion, the deformation in m is just symbolic, you can go to the working directory and look for the .out file, then see
http://forum.altairhyperworks.com/index.php?/topic/15947-frequency-units/#comment-28109
