Is it possible to control the number of processors used by the CPU when running a solver based analysis in HyperStudy?
Which solver you are using?
Did you try Hst Multiexecute?HST only controls how many simultaneous runs are allowed, the solver itself (OptiStruct) should be able to control how many cpus are used by a single run, I believe this is the -ncpu option for Optistruct.
