Hello I have a question about preparing geometry to mesh. After using midsurface there is small gap between joined profiles.
1) Before meshing I need to extend vertical element to the horizontal one to have yellow lines and to have common edge?
2) If yes, how to do it if my geometry is not perfect and side surfaces of 2 profiles and not in the same plane. How can I perfectly locate 2 surfaces to each other? In my model 1 extended surface hits target surface too far and on another side miss target because of dislocation.
Help me please
