Dear sir
i hv done springback analysis
i hv got .rad file and animation result file after doing analysis
but how i can see result plz help and i am faculty not a commercial costomer
Hi Sachinhw,
Please refer to the replies of the forum post:
http://forum.altairhyperworks.com/index.php?/topic/14057-forming-setup/
i need to springback values from the result
i hv done springback analysis using user process analysis run successfully
but i want to knw that how i come to know how much springback has occure
which result i used to see either displacement or thickness or other to interpretate springback
hi Sachin,
you can use the 000.rad file before the springback and .sta file generated after inspiring back in HF to compare the results. Go to Tools>> Springback comparison. choose the .rad file as reference part. refer the attached file for steps.
thank you so much sir i am looking for this thank you
hi sir i get the result of springback in magnitude, but what is the unit of this magnitude?
