What is the stick contact interface ? how is it different from freeze?
Ahilan,
Prescribing TYPE=FREEZE enforces zero relative motion on the contact surface – the contact gap opening remains fixed at the original value and the sliding distance is forced to be zero. Also, rotations at the slave node are matched to the rotations of the master patch. The FREEZE condition applies to all respective contact elements, no matter whether open or closed.
