Get Temp Node IDs From Last Operation
User: "Jeffersondhv"
Altair Community Member
Updated by Jeffersondhv
Hello guys,
I have some points in my model that will be used to create connectors. In order to handle them in a proper manner, I need to transform them into nodes and them get the node IDs to create a node set.
To create the nodes from the points I'm using this function: *nodecreateatpointmark 1
However this is one of the undocumented functions, thus I don't know if it has other options to use, because using as I showed does not return me the node IDs.
I also tried to use hm_latestentityid but this one gives me only one node at a time and has a limitation to retrieve only the last 99 nodes and I might need more than that in most of the cases.
Does anybody know a solution for this?
Thanks in advance,
Jefferson Vieira
1 - 1 of 11
