I want to change the magnitude and direction of the following applied load.I tried update but it is not getting changed.
select your load, change the values and press update. Then you have to choose another time which type of update you want to make. Select e.g. vector and magnitude (hook) and press again update.
Best regards,
Mario
Thanks mario
