Dear Sirs,
   	I have an antenna design ready and i need optimize some parameters in the design in order to improve the performance, like the SLL and the BW.
   	In OPTFEKO module the goals are very limited.
   	For example, for the far field we only can calculate the maximun or the average... I need for example calculate de SLL.... Is possible with editfeko or another module.... I dont know..
   	I understand that in each iteration the program calculates  far field, so i only need process this result and take a value (the SLL for example or another) and use this in the goal function with the correct weight.
   	Thanks.
