Hi
I have simulated my model using the current source and get the right answer compare to my reference. I need to use voltage source to model my motor and get the current for fault analysis (eccentricity/short circuit faults).
When I used voltage source, I can't get the expected results and the current is extremely high.
What is the solution to solve it?
