Combine Derived Results
Hello to everyone,
This is a very easy question, but I have not found out the way to do it, so I decided to ask you.
I have computed a simulation of a plate with some forces on it, and, as usual, I have the displacement field at each node (I will call this variable, which is a vector, Disp).
Now, I compute this derived result: V1 = 2*Disp. I do it as usual, in the expression builder I select variable 'Displacement'.
Then, I have in the vector tree a new variable called V1.
Again, I would like to calculate a derived result involving this new variable V1, for example, S1 = dot[V1,Disp]. And here is my question: When I try to select in the expression builder the variable computed previously, I can not find it. So, do you know how can I make a computation over the derived results computed previously?
I know I could do it at the same time (S1 = dot[V1,Disp] = dot[2*Disp,Disp] = 2*dot[Disp,Disp]), but I would like to learn how to do it separately in order to do more complex computations between different loadcases.
Thank you in advance!
Hi @Angelito
I dont see a way to include derived results in functions.
I will check with experts on the same and will provide any workaround to you soon.
Thanks!
Do you have any news about this issue?
Thank you in advance.
Hi @Angelito
So far I did not have a workaround, I will raise a RFE to add such feature if possible.
Hi @Angelito
